I am using python and clipping a tif with the clip tool. However, the output (clipped) raster is altered. The raster properties appear identical, both 16bit signed. Cell sizes are the same etc. Here is the relevant code including environment parameters:
<SPAN class="">arcpy</SPAN><SPAN class="">.</SPAN><SPAN class="">env</SPAN><SPAN class="">.</SPAN><SPAN class="">compression </SPAN><SPAN class="">=</SPAN><SPAN class=""> </SPAN><SPAN class="">"NONE"</SPAN>
<SPAN class="">arcpy</SPAN><SPAN class="">.</SPAN><SPAN class="">env</SPAN><SPAN class="">.</SPAN><SPAN class="">pyramid </SPAN><SPAN class="">=</SPAN><SPAN class=""> </SPAN><SPAN class="">"NONE"</SPAN>
<SPAN class="">arcpy</SPAN><SPAN class="">.</SPAN><SPAN class="">Clip_management</SPAN><SPAN class="">(</SPAN><SPAN class="">pl_rasters</SPAN><SPAN class="">[</SPAN><SPAN class="">0</SPAN><SPAN class="">],</SPAN><SPAN class=""> buffExtentStrip</SPAN><SPAN class="">,</SPAN><SPAN class=""> pluvial_final</SPAN><SPAN class="">+</SPAN><SPAN class="">".tif"</SPAN><SPAN class="">,</SPAN><SPAN class="">nodata_value</SPAN><SPAN class="">=-</SPAN><SPAN class="">9999</SPAN><SPAN class="">,</SPAN><SPAN class="">maintain_clipping_extent</SPAN><SPAN class="">=</SPAN><SPAN class="">"NO_MAINTAIN_EXTENT"</SPAN><SPAN class="">)</SPAN>
The following images show the original and clipped.
Original:
Clipped:
Any help is greatly appreciated.
NO_MAINTAIN_EXTENT —The cell alignment of the input raster will be maintained and the output extent will be adjusted accordingly.
The description for the tool describes several examples where the extent and/or cell size can be altered during the process. Your code example provides several opportunities for that to occur. It might be worth while to experiment by setting your environment parameters explicitly in the code (ie cell size, alignment and the clip extent)
resolved?
