I know this was posted a long time ago but....If anyone has this same problem, be sure the the Data Frame your feature classes are in is Active. I just spent 30 minutes trying to resolve the problem and realized I had the wrong data frame active.
I got the same problem. It was found that it was due to the crashed SDE DB. After re-building the DB and creation of the version, the problem was gone.
Closing ArcMap and restarting solved my problem on this issue. Anyone know why?
I only have a little bit of server experience but are you sure they are Feature Access enabled? If not, republish with Feature Access in order to edit.
I have a similar problem but I am using file geodatabases. The geodb is on a local server. I've noticed it tends to happen when I have lots of layers in the map (not sure if it is the multiple projections of different files that could be causing the issue - this is the only thing I can really put it down too). My dataframe and geodb are in the same projection.
There are no permission issues (I administer this particular local drive).
The only work around I have is to close ArcMap and reopen a blank map. Then add the layer I want to add (and maybe a few references layers). I can then edit the geodatabase no worries.
I also can't copy a layer from one map to a new blank map ... I will have the same issues with no editable layers.
Anyone else have any thoughts?? Resolutions??
Thanks! This was my problem... the correct layer frame was not active! Whew! Thanks again!
Ugh, thank you!!!! I was really starting to loose it, then I found your post. Phew!
