i have ArcGIS pro 2.5.2 and it constantly crashes immediately when i run the aspect slope tool from the raster functions.no errors or anything the application just closes in a second.
this has been solved in the 2.6 update for Pro
Thanks but this is aspect only, the function i mean generates a combination of slope and aspect with special symbologyNew Aspect-Slope Raster Function Now Available
Aspect (Spatial Analyst)—ArcGIS Pro | Documentation open arctoolbox in Pro and if you have the spatial analyst or 3D analyst extension it is there. You can search arctoolbox in Pro as well.
If you are doing this in a script, you will need to post the script in case the function has nothing to do with the failure. If you are getting errors, provide the full trackback error message.
i don't find the tool in the toolbox it's only available as a raster function, which i have in ArcMap as an external python code ! but the implemented one in ArcGIS Pro just make the software close, no error or warnings or whatever !maybe a bug or so
have you tried the Slope aspect tool in the spatial analyst or 3d analyst toolbox?
If it is failing immediately, then you may need to provide your inputs to see if they are path and coordinate system compliant
