I am not a developer, but I want to use a python script from a former colleague. Parts of the script clip the current extent in ArcMap to the clipboard. It works well iwthhin in Addin on my Virtual Machine. If I use the same script/addin on my notebook (with a differnt user though) in the companies network, it doesn´t work. Any ideas? How do I have to modify the script?
import arcpy
import pythonaddins
from Tkinter import Tk
import os
class XY_Kopieren(object):
"""Implementation for ToeB_addin.button (Button)"""
def __init__(self):
self.enabled = True
self.checked = False
def onClick(self):
mxd = arcpy.mapping.MapDocument('current')
activeDataFrame = mxd.activeView
df = arcpy.mapping.ListDataFrames(mxd,"Layers")[0]
xmin = df.extent.XMin
xmax = df.extent.XMax
ymin = df.extent.YMin
ymax = df.extent.YMax
r = Tk()
r.withdraw()
r.clipboard_clear()
r.clipboard_append(str(xmin)[0:6] + ',' + str(ymin)[0:7] + ',' + str(xmax)[0:6] + ',' + str(ymax)[0:7])
r.destroy()
pythonaddins.MessageBox('Die Koordinaten des aktuellen Raumausschnittes wurden in die Zwischenablage kopiert.', 'INFO', 0)
pass
@Jake Skinner () published a similar Add-In called Extent Python Add-In. It works well my has blank spaces between the coordinates and decimals in it. I would need the coordinates copied like 334736,5658853,417290,57118 to the clipboard to use it in a second application. Can I change an Add-In? If not. Can you @jskinner_CountySandbox help?
