API JS 3.1Hi everyone, I use the esri.dijit.editing.Editor to edit my layers. Unfortunately, I don't want to use the popup on the elements provided by the Editor because I have to use complex forms on my own.But the Editor call standards popup wathever I do.Any idea? Thanks by advanceMy simplified code about the Editorvar layerInfos = new Array();
function initEditor(){
for(var i=0; i<userConfig.layerItems.length; i++){
var layer = map.getLayer(userConfig.layerItems.uniqueID);
if(layer.fields!=undefined){
var fieldInfos = dojo.map(layer.fields, function(field) {
if (field.name === 'description') {
return {
'fieldName' : field.name,
'label' : 'Details',
stringFieldOption : esri.dijit.AttributeInspector.STRING_FIELD_OPTION_TEXTAREA
} else {
return {
'label' : field.alias
dojo.connect(layer, "onEditsComplete", openForm);
dojo.connect(layer, "onClick", openForm);
// Ajout aux layerInfos
layerInfos.push({
featureLayer : layer,
fieldInfos : fieldInfos
var params = {
settings : {
map : map,
enableUndoRedo : true,
layerInfos : layerInfos,
toolbarVisible : true,
createOptions : {
polygonDrawTools : [
esri.dijit.editing.Editor.CREATE_TOOL_FREEHAND_POLYGON,
esri.dijit.editing.Editor.CREATE_TOOL_AUTOCOMPLETE ]
toolbarOptions : {
reshapeVisible : true,
cutVisible : true,
mergeVisible : true
editorWidget = new esri.dijit.editing.Editor(params, 'editorDiv');
editorWidget.startup();
function openForm(){
alert("Form");
console.log(this);
