Hello all,I know this is probably a very simple question but I am stuck. I created a combo box and placed it on a tool bar. I would like to adjust the width of the combo box; however, I can't find the properties. Any help is greatly appreciated. Thanks,James
Thank you. I looked at the Config.esriaddinx and didn't see anything about size. after reading your post I added sizeString="WWWWWWWWWWWWWWWWWW" to the config and it works perfectly.Thanks a lot!James
Thanks.......I just added a new combobox to see how the setup worked. I overlooked those properties before. I actually have another question along the same lines; however, this may be better suited for a new thread. How do I access the combobox form another component. For example if I create a button and in it's OnClick event I want to add "Hello" and "World" to the combo box. I assume I access this through the namespace of the command but am not having any luck.As always thanks for the help,James
Thank you! I didn't think about creating an add/clear procedure. I assumed that I would be able to access the add function of the combo box. This is great stuff!!!
