Any help or a link to a source on creating legends will be greatly appreciated. tahnsk in advance.
Which map are we talking about?
Please be more descriptive about the issue you are facing. Below are some point that you can add to you post which will make the other developers understand the problem and provide you solutions.
Thanks so much-
Here is the map-
http://jsbin.com/hobege/edit?html,output
here is what I’m trying to do-
Add magnitude-dependent styling for the earthquakes
- Add a title to the plot -
-Add labels that indicate the number of earthquakes of various sizes
- Add a legend for the styling
-Add a legend. Create your own custom legend.
Thanks again
Hello Manisha
Does you application has anything to do with ArcGIS or ArcGIS JavaScript API? It doesn't look like you are using it.
I would like to be able to use ArcGIS Javascript. Is it possible?
