map.addLayer(subeventsGraphicsLayer);
var SubEventpt; var SubEventsymbol; var SubEventgraphic; var SubEventgraphics = new Array; var subeventsGraphicsLayer = new esri.layers.GraphicsLayer(); $.each(event.Subevents(), function (i, subevent) { SubEventpt = webMercatorUtils.geographicToWebMercator(new Point(subevent.Longitude, subevent.Latitude)); SubEventsymbol = new PictureMarkerSymbol('../Images/Incidents/' + subevent.IconPath, 36, 36); SubEventgraphic = self._map.addGraphic(new Graphic(SubEventpt, SubEventsymbol, ko.toJS(subevent))); SubEventgraphic = new Graphic(SubEventpt, SubEventsymbol, ko.toJS(subevent)); SubEventgraphics.push[SubEventgraphic]; }); subeventsGraphicsLayer.add(SubEventgraphics); self._map.add(subeventsGraphicsLayer);
Sorry I can't put it into a js fiddle, its way to complicated. But currently I am using a jquery for each to take the graphics and push each one into a variable that I defined as a array and then I am pushing the graphics into it. I am then taking the graphics array and adding the array to a new esri.layers.GraphicsLayer. And I am trying to push the graphics layer to the map. Currently I am getting an error that self._map.add(GraphicsLayer) is undefined. I have been debugging and I can see self._map is finding the div object map however it doesn't seem to be able find the add function.
