<map initialextent="-14083000 3139000 -10879000 5458000" top="40" zoomslidervisible="false" addarcgisbasemaps="true" wraparound180="true"> <basemaps> <layer label="Streets" type="tiled" visible="true" alpha="1" icon="assets/images/basemap_streets.jpg" url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer"/> </basemaps>
Lefteris, Sounds like you need to check that the assets for the streets thumbnail does exist in your projectassets/images/basemap_streets.jpg
Dan, Sure the method is when you use the addarcgisbasemaps="true" attribute in the map tag it will append available basemaps from the ArcGIS Portal to your map (meaning if you have manually add a particular base map than it will be the first on that is loaded and visible and all the remaining basemaps for the portal will be added after that one).Example: <map initialextent="-14083000 3139000 -10879000 5458000" top="40" zoomslidervisible="false" addarcgisbasemaps="true" wraparound180="true"> <basemaps> <layer label="Streets" type="tiled" visible="true" alpha="1" icon="assets/images/basemap_streets.jpg" url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer"/> </basemaps>Don't forget to click the Mark as answer check on this post and to click the top arrow (promote).Follow the steps as shown in the below graphic:
<map wraparound180="true" initialextent="-14083000 3139000 -10879000 5458000" fullextent="-20000000 -20000000 20000000 20000000" top="40" addarcgisbasemaps="true"> <basemaps> <layer label="Imagery with Labels" type="tiled" visible="true" alpha="1" icon="http://www.arcgis.com/sharing/content/items/716b600dbbac433faa4bec9220c76b3a/info/thumbnail/imagery_with_labels_ne_usa.png" url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer"/> <layer label="Imagery with Labels" type="tiled" visible="true" alpha="1" icon="http://www.arcgis.com/sharing/content/items/716b600dbbac433faa4bec9220c76b3a/info/thumbnail/imagery_with_labels_ne_usa.png" url="http://server.arcgisonline.com/ArcGIS/rest/services/Reference/World_Boundaries_and_Places/MapServer"/> </basemaps>
