import arcpy, os from arcpy import env import sys import time try: t0 = time.clock() env.workspace = r"C:\ags\python" sdeConn = arcpy.ArcSDESQLExecute(r"C:\ags\gp\gisselect_cdodb_t.sde") sql = "SELECT lon, lat, snow FROM gis.snow_sum_partitioned WHERE date_time = to_date('19991231','yyyymmdd') AND snow IS NOT NULL" try: # execute SQL statement sdeReturn = sdeConn.execute(sql) except Exception, ErrorDesc: print ErrorDesc sdeReturn = False # if return value is a list (a list of lists), display each list as a row from the table being queried. if isinstance(sdeReturn, list): # set spatial reference prjFile = "geo_wgs84.prj" spatialRef = arcpy.SpatialReference(prjFile) tmpWorkspace = "in_memory" outXYfc = "XY_FeatureClass" # create in_memory empty feature class arcpy.CreateFeatureclass_management(tmpWorkspace, outXYfc , "POINT", "", "", "", spatialRef) # build tmp FC path and add new field for values to interpolate tmpFC = os.path.join(tmpWorkspace, outXYfc) arcpy.AddField_management(tmpFC, "Snow", "DOUBLE") # create insert cursor inCur = arcpy.InsertCursor(tmpFC) for rec in sdeReturn: pnt = arcpy.Point(rec[0], rec[1]) row = inCur.newRow() row.Shape = pnt row.Snow = rec[2] inCur.insertRow(row) del inCur, row # Set layer symbology symbology_layer = "snow_symbology.lyr" arcpy.ApplySymbologyFromLayer_management(outXYfc, symbology_layer) else: # If the return value was not a list, the statement was most likely a DDL statment. Check its status. if sdeReturn == True: print "SQL statement: " + sql + " ran sucessfully." else: print "SQL statement: " + sql + " FAILED." except Exception, ErrorDesc: print Exception, ErrorDesc except: print "Problem executing SQL."
gp.createtable_management("IN_MEMORY", "TempDT", "", "") cxRows = cursor.fetchall() #the cursor here was already filled. rowcount = cursor.rowcount for row in range(1, rowcount - 1): tables = gp.ListTables() for tbl in tables: if tbl=="TempDT": ### add the fields for i in range(0, len(cursor.description)): val1 = str(cursor.description[0]) val2 = str(cursor.description[1]) val3 = str(cursor.description[2]) if val2=="<type 'cx_Oracle.STRING'>": fldType = "Text" val3 = cursor.description[2] gp.AddField(tbl, str(cursor.description[0]), fldType, val3) if val2=="<type 'cx_Oracle.NATIVE_FLOAT'>": fldType = "Float" gp.AddField(tbl, str(cursor.description[0]), fldType) if val2=="<type 'cx_Oracle.DATETIME'>": fldType = "Date" gp.AddField(tbl, str(cursor.description[0]), fldType) ### now populate the table insRows = gp.InsertCursor(tblNew) for cxRow in cxRows: insRow = insRows.newRow() for i in range(0, len(cursor.description)): insRow.setvalue(str(cursor.description[0]), cxRow) insRows.insertRow(insRow) cursor.close() db.close()
