Mike,The map in use by the Map View tab is set in another location (at least at 10.0). If you select Setting from the top menu and then Workflow Manager System Settings, an interface will open. There should be a Map Views tab where you can define the Job Result Map View. I hope this is what you were looking for.Alison
