Hello ,
I am having a data set with negative value for temperature. What value should be given to these fields so that my hot spot analysis calculation is not effected by these values.
if you are using a point file/layer as input, it would be wiser, if you selected/queried for the valid data (ie not null) then export that to a separate layer...that would be the safest
