I have a standalone table in an ArcGIS rest service that I need to query. The service has security requiring a username and password. I used this table in 10.2.6 applications using credentials and querytask without a problem. Is there a way in runtime to query this table? Do I have to use NetworkRequest, which is more complicated with tokens?
You can do that with a ServiceFeatureTable. This sample showcases this with a feature layer for viewing, but you don't need to display it - you could just query the ServiceFeatureTable directly - arcgis-runtime-samples-qt/ArcGISRuntimeSDKQt_QMLSamples/Features/FeatureLayer_Query at master · Esri/arcgis-runtime-samp…
As for the authorization component, you can do that a few ways. You can create a Credential object with username and password, and set that on the ServiceFeatureTable. You could also use the AuthenticationManager workflow, which is discussed here - Access the ArcGIS platform—ArcGIS Runtime SDK for Qt | ArcGIS for Developers
Hi Lucas,
That was the first thing I tried and apparently since the table has no geometry that doesn't work.
Tables with no geometry should work. Here is an example:
<SPAN class="keyword token">import</SPAN> QtQuick <SPAN class="number token">2.6</SPAN> <SPAN class="keyword token">import</SPAN> QtQuick<SPAN class="punctuation token">.</SPAN>Controls <SPAN class="number token">2.2</SPAN> <SPAN class="keyword token">import</SPAN> Esri<SPAN class="punctuation token">.</SPAN>ArcGISRuntime <SPAN class="number token">100.6</SPAN> ApplicationWindow <SPAN class="punctuation token">{</SPAN> id<SPAN class="punctuation token">:</SPAN> appWindow width<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">800</SPAN> height<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">600</SPAN> title<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Untitled81"</SPAN> ServiceFeatureTable <SPAN class="punctuation token">{</SPAN> url<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"https://services2.arcgis.com/ZQgQTuoyBrtmoGdP/arcgis/rest/services/AlaskaNationalParksPreservesSpecies_List/FeatureServer/2"</SPAN> Component<SPAN class="punctuation token">.</SPAN>onCompleted<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="token function">load</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">}</SPAN> onLoadStatusChanged<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>loadStatus <SPAN class="operator token">===</SPAN> Enums<SPAN class="punctuation token">.</SPAN>LoadStatusLoaded<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"loaded"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="token function">queryFeatures</SPAN><SPAN class="punctuation token">(</SPAN>params<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN> onQueryFeaturesStatusChanged<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>queryFeaturesStatus <SPAN class="operator token">===</SPAN> Enums<SPAN class="punctuation token">.</SPAN>TaskStatusCompleted<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"complete"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">let</SPAN> iter <SPAN class="operator token">=</SPAN> queryFeaturesResult<SPAN class="punctuation token">.</SPAN>iterator<SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">while</SPAN> <SPAN class="punctuation token">(</SPAN>iter<SPAN class="punctuation token">.</SPAN>hasNext<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> feat <SPAN class="operator token">=</SPAN> iter<SPAN class="punctuation token">.</SPAN><SPAN class="token function">next</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN>JSON<SPAN class="punctuation token">.</SPAN><SPAN class="token function">stringify</SPAN><SPAN class="punctuation token">(</SPAN>feat<SPAN class="punctuation token">.</SPAN>attributes<SPAN class="punctuation token">.</SPAN>attributesJson<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN> QueryParameters <SPAN class="punctuation token">{</SPAN> id<SPAN class="punctuation token">:</SPAN> params whereClause<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"1=1"</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
The service in the example you provided the table has an objectid. Ours does not and that may cause problems.
Here is the error.
qml: Suggest like '%2%' and LayerField like 'Parcels-Site_Address'
ArcGIS.AppFramework.Player: Object: QObject(0x0) Text: "file:///C:/Users/huntj/ArcGIS/AppStudio/Apps/6154a8cf097142b38e223b3d9abc999d/MonTopo2.qml:351: TypeError: Cannot read property 'iterator' of null"
I got it. I made a typo which caused the error.
