<operationallayers> <layer label="XYZ Test of Edit" type="dynamic" visible="false" alpha="1.0" url="https://url.com/ArcGIS/rest/services/XYZ/FeatureServer"/> <layer label="Editable Features" type="feature" visible="true" info="widgets/InfoTemplates/SimpleInfoWinWidget.swf" infoconfig="widgets/InfoTemplates/test.xml" url="https://url.com/ArcGIS/rest/services/XYZ/FeatureServer/0"/> </operationallayers>
Feature Layer: EditLines (ID: 0) View In: ArcGIS.com Map Display Field: SITECODE Type: Feature Layer Geometry Type: esriGeometryPolyline Description: Copyright Text: Min. Scale: 0 Max. Scale: 0 Extent: XMin: 559357.9375 YMin: 114810.068100002 XMax: 594669.064499997 YMax: 153591.5735 Spatial Reference: 32149 Drawing Info: Renderer: Simple Renderer: Symbol: Simple Line Symbol: Style: esriSLSSolid, Color: [161, 0, 56, 255], Width: 1 Label: Lines Description: Transparency: 0 Labeling Info: N/A Has Attachments: False HTML Popup Type: esriServerHTMLPopupTypeNone Object ID Field: OBJECTID Global ID Field: Type ID Field: Fields: OBJECTID (Type: esriFieldTypeOID, Alias: OBJECTID, Editable: False) DEC_UNIT (Type: esriFieldTypeString, Alias: DEC_UNIT, Length: 15, Editable: True, Domain: Coded Values: [100-B/C: 100-B/C], [100-D/H: 100-D/H], [100-F/IU-2/IU-6: 100-F/IU-2/IU-6], ...5 more...) Templates: Name: EditLines Description: Drawing Tool: esriFeatureEditToolLine Prototype: Attributes: DEC_UNIT: Supported Interfaces: REST Supported Operations: Query Add Features Update Features Delete Features Apply Edits
ID: Sprayed Name: Sprayed Domains: Field Name: INSTALLATIONID Inherited Field Name: SITEID Inherited Field Name: REALPROPERTYSITEUNIQUEID Inherited Field Name: OWNER Inherited Templates: Name: Sprayed Description: Drawing Tool: esriFeatureEditToolPolygon Prototype: Attributes: PRIORITY: None STATUS: Sprayed -------------------------------------------------------------------------------- ID: Plowed Name: Plowed Domains: Field Name: INSTALLATIONID Inherited Field Name: SITEID Inherited Field Name: REALPROPERTYSITEUNIQUEID Inherited Field Name: OWNER Inherited Templates: Name: Plowed Description: Drawing Tool: esriFeatureEditToolPolygon Prototype: Attributes: PRIORITY: None STATUS: Plowed
Feature Layer: XYZ.PavementBranch (ID: 0) View In: ArcGIS.com Map Display Field: FEATURENAME Type: Feature Layer Geometry Type: esriGeometryPolygon Description: Copyright Text: Min. Scale: 0 Max. Scale: 0 Extent: XMin: -5.63324851099998 YMin: 36.984785175 XMax: 35.456580847 YMax: 56.174739496 Spatial Reference: 4326 Drawing Info: Renderer: Unique Value Renderer: Field 1: PCI Field 2: Field 3: Field Delimiter: , Default Symbol: Unsupported Symbol Default Label: Unique Value Infos: Value: 0 Label: CLEAR Description: Symbol: Simple Fill Symbol: Style: esriSFSSolid, Color: [182, 252, 184, 255] Outline: Simple Line Symbol: Style: esriSLSSolid, Color: [110, 110, 110, 255], Width: 0.4 Value: 1 Label: Test Description: Symbol: Simple Fill Symbol: Style: esriSFSSolid, Color: [255, 190, 190, 255] Outline: Simple Line Symbol: Style: esriSLSSolid, Color: [0, 0, 0, 255], Width: 0.4 Value: 2 Label: Test2 Description: Symbol: Simple Fill Symbol: Style: esriSFSSolid, Color: [190, 232, 255, 255] Outline: ... Simple Line Symbol: Style: esriSLSSolid, Color: [0, 0, 0, 255], Width: 0.4 Transparency: 0 Labeling Info: N/A Has Attachments: False HTML Popup Type: esriServerHTMLPopupTypeAsHTMLText Object ID Field: OBJECTID Global ID Field: GLOBALID Type ID Field: PCI Fields: ... PCI (Type: esriFieldTypeInteger, Alias: PavementConditionIndex, Editable: True) ... Types: ... ... -------------------------------------------------------------------------------- Supported Interfaces: REST Supported Operations: Query Add Features Update Features Delete Features Apply Edits
<operationallayers> <layer label="XYZ Test of Edit" type="dynamic" visible="false" alpha="1.0" url="https://url.com/ArcGIS/rest/services/XYZ/FeatureServer"/> <layer label="Editable Features" type="feature" visible="false" info="widgets/InfoTemplates/SimpleInfoWinWidget.swf" infoconfig="widgets/InfoTemplates/test.xml" url="https://url.com/ArcGIS/rest/services/XYZ/FeatureServer/0"/> </operationallayers> <widget label="Edit Test" icon="assets/images/i_edit.png" config="widgets/Edit/EditWidget.xml" url="widgets/Edit/EditWidget.swf"/>
<?xml version="1.0" ?> <configuration> <createoptions> <polygondrawtools>polygon,freehandpolygon,extent,autocomplete</polygondrawtools> <polylinedrawtools>polyline,freehandpolyline,line</polylinedrawtools> </createoptions> <addfeatures>true</addfeatures> <deletefeatures>true</deletefeatures> <toolbarvisible>true</toolbarvisible> <toolbarcutvisible>true</toolbarcutvisible> <toolbarmergevisible>true</toolbarmergevisible> <toolbarreshapevisible>true</toolbarreshapevisible> <updategeometry>true</updategeometry> <updateattributes>true</updateattributes> <showcreatorfield>true</showcreatorfield> <showcreationdatefield>true</showcreationdatefield> <showeditorfield>true</showeditorfield> <showeditdatefield>true</showeditdatefield> </configuration>
I only have one attribute I want to be updatable (click on the existing feature and have a drop down selection of 1,2,3 or 4), no drawing/adding features.
Is there a walk-through example of creating template? I only have one attribute I want to be updatable (click on the existing feature and have a drop down selection of 1,2,3 or 4), no drawing/adding features.
Yes, that is possible with the Edit widget. Your data needs to be coming from an ArcGIS Server Feature Service (and be editable).See http://resources.arcgis.com/en/help/flex-viewer/concepts/index.html#/Edit_widget/01m30000003v000000/Live sample: http://resources.arcgis.com/en/help/flex-viewer/live/index.html?config=apps/config-edit.xml
Is this possible with the editwidget or some other widget: Allow users via the webviewer to click on a feature in a featurelayer and have a popup show the value for a particular field for that featuer and allow the user to edit that value (from a dropdown of selections)? I don't see how to do this. Any help is appreciated.
