Is it possible for ArcHydro to bring pipe size, slope, friction coefficients into an analysis to model capacity constraints? If I calculated how much water a storm inlet (or series of inlets) were to capture for say a 100 year storm, could ArcHydro analyze if the downstream pipe network can handle it? Or is this beyond the scope of ArcHydro at this time in its development?.
I'm connecting a few dots and for storm inlet structures and pipes, I'm assuming you build the pipe into a sink with parallel walls on each side, ending the walls at the inlets/outlets to let the water in/out and creating what ArcHydro sees as a channel for the water?
Likely more than you asked for.... Hope this helps.
