You are quite correct that the raster should be georeffed into its real projected system.But if you have a graticule on the map marked in GCS you can enter these cords directly.After clicking on the "from" point using the GeoRef toolbar, if you right click, it gives you the opportunity to type in the known coords of the point in DMS or DD, these locations are then immediately projected into the PCS units, and will appear in the link table as metres or whatever it is.This is particularly useful when georeffing scanned map sheets where the corners are usually marked in Lat/Long but the map is UTM or whatever.Good luck,Neil
