When both engine and desktop 10.2 are installed on the same machine. GetInstallInfo('desktop') returns information for the engine install. See the sample code below.
import arcinfo
import arcpy
arcpy.SetProduct('ArcInfo')
for install in arcpy.ListInstallations():
print('\nINFO: for ' + install + ' installation')
# Use the dictionary iteritems to iterate through
# the key/value pairs from GetInstallInfo
d = arcpy.GetInstallInfo(install)
for key, value in d.iteritems():
# Print a formatted string of the install key and its value
print("{:<13} : {}".format(key, value))
INFO: for desktop installation
SourceDir : ...\ESRI\ArcGIS10.2.2\Engine\windows\SetupFiles\
InstallDate : 7/28/2014
InstallDir : c:\arcgis\engine10.2\
ProductName : Engine
BuildNumber : 3552
InstallType : Typical
Version : 10.2.2
SPNumber : N/A
Installer : install_user
SPBuild : N/A
InstallTime : 12:48:48
INFO: for engine installation
The GetInstallInfo (arcpy) does not use the provided parameter. See the help:
ArcGIS Help (10.2, 10.2.1, and 10.2.2)
In my ase it returns this output (twice the same info):
INFO: for desktop installation SourceDir : C:\Users\xbakker\Documents\ArcGIS 10.3\Desktop\SetupFiles\ InstallDate : 2014/12/16 InstallDir : c:\program files (x86)\arcgis\desktop10.3\ ProductName : Desktop BuildNumber : 4322 InstallType : N/A Version : 10.3 SPNumber : N/A Installer : xbakker SPBuild : N/A InstallTime : 16:07:59 INFO: for explorer installation SourceDir : C:\Users\xbakker\Documents\ArcGIS 10.3\Desktop\SetupFiles\ InstallDate : 2014/12/16 InstallDir : c:\program files (x86)\arcgis\desktop10.3\ ProductName : Desktop BuildNumber : 4322 InstallType : N/A Version : 10.3 SPNumber : N/A Installer : xbakker SPBuild : N/A InstallTime : 16:07:59
BTW: you can remove the line:
This does not do anything, since the license level is determined when you import arcpy or as you do with setting the license level using the import arcinfo. Note that in 10.3 there is a bug and it you cannot set the license level from a stand alone script, it will simply consume the highest license available...
Xander,
What method should be used to return only desktop installation directory? The developer used GetInstallInfo()[InstallDir] in the past, but that won't work when both engine and desktop are on the same machine.
Regards,
John P. Lovato
The alternative could be looking at the path settings:
import sys for p in sys.path: p = p.lower() if "arcgis\\desktop" in p and p.endswith('bin'): print p
Thank you Xander. I'll see if this will work for the developer. It looks like it gives the correct information for me.
There are a couple of things going on here. First, arcpy.GetInstallInfo has no parameters. It will accept an argument and not throw an error, but any argument that is passed doesn't affect the results of what is returned. The arcpy.GetInstallInfo function gets the installation information that relates to the currently loaded ArcPy site package, which in your case is ArcGIS Engine.
If you install ArcGIS Desktop and ArcGIS Engine on the same machine using standard installation instructions, the two will share a single Python interpreter, usually C:\Python27\ArcGIS10.x (10.2 in this case). Another way to look at it is that a single Python interpreter has 2 ArcPy site packages registered/installed. Since the site packages have the same name (arcpy), they both can't be loaded into the interpreter at the same time. When the interpreter encounters an import arcpy statement, it will find and import whichever site package is found first in the search path for modules, i.e., sys.path.
Before importing ArcPy, you can quickly determine which ArcPy site package will be loaded by running:
import imp imp.find_module('arcpy')
In this case, the result will come back with ...\Engine10.2\... since it comes first in the sys.path. Reversing the order of sys.path before importing ArcPy will likely find and import the Desktop site package for your situation.
import imp import sys sys.path.reverse() imp.find_module('arcpy')
The issue with reversing sys.path out of hand is that it will import the Engine-based site package if ArcGIS Engine was installed first. There are a couple of more thoughtful ways to get around this problem. First, setting the PYTHONPATH Windows environment variable to the Desktop-based site package will ensure that it is loaded first regardless of the sys.path order. However, in this case, it seems you don't already know that location and am trying to figure it out. A second approach would be to remove all of the Engine-related entries in sys.path before import arcpy.
import sys for p in sys.path[:]: if 'Engine' in p: sys.path.remove(p)
If the goal is to determine whether ArcGIS Desktop is installed and where, maybe querying a WMI service for installed applications and information is a better approach. Adapted from the Microsoft Script Center List Installed Software Python script:
import win32com.client objWMIService = win32com.client.Dispatch("WbemScripting.SWbemLocator") objSWbemServices = objWMIService.ConnectServer(".", "root\cimv2") colItems = objSWbemServices.ExecQuery("Select * from Win32_Product " "where Name Like 'ArcGIS % for Desktop'") for objItem in colItems: print "Name: ", objItem.Name print "Install Date: ", objItem.InstallDate print "Install Location: ", objItem.InstallLocation print ""
