I'm not sure what the absolute or floating split does in splitting a facade using facade wizard. Do we need to use floating for the repetitive tiles? How do they differ? I appreciate any explanations.
Yes, you can have repeating splits with floating and absolute sizes.
In a split, elements specified by absolute sizes will have exactly those sizes. For example, if the facade has a width of 10, and the repeat split tries to divide it into elements of absolute size 3, then you will get 4 pieces. The first three will have size 3, and the fourth will have size 1.
split(x) { 3 : A. }*
If a repeating split contains floating sizes, then the split will divide the shape into as many pieces as it can that have a size close to the specified floating size. In this example, the result would be 3 shapes each of width 3.33.
split(x) { ~3 : A. }*
See the examples for floating and absolute splits on the help page for more info:
split Operation
Working with the Repeat Split
