Private Sub MakeHighwayDistrictBoundaryLists() 'finds unique values from pData.Field value in Polygon Layer Dim pDoc As IMxDocument Set pDoc = ThisDocument Set pPointLayer = pDoc.FocusMap.Layer(0) Set pPolyLayer = pDoc.FocusMap.Layer(10) 'Set Polygon Layer name for labelling output table strLName = pPolyLayer.Name strPolyVariable = "DISTRICT" MakeList End Sub Private Sub MakeList() Dim pDoc As IMxDocument Set pDoc = ThisDocument Dim pMap As IMap Set pMap = pDoc.FocusMap Dim pData As IDataStatistics Dim pCursor As ICursor Dim pEnumVar As IEnumVariantSimple Dim pTable As ITable Set pTable = pPolyLayer Set pCursor = pTable.Search(Nothing, False) Set pData = New DataStatistics pData.Field = strPolyVariable Set pData.Cursor = pCursor Set pEnumVar = pData.UniqueValues Value = pEnumVar.Next Dim DiagCollection As New Collection Dim Inst Do Until IsEmpty(Value) If Value = " " Then Value = pEnumVar.Next Else 'Selects Polygon form pPolyLayer that match the variable Value Dim pSelectedPoly As IFeatureSelection Set pSelectedPoly = pPolyLayer 'QI Dim strQuery As String If strPolyVariable = "ZIPCODE" Or strPolyVariable = "SANAREA" Or strPolyVariable = "DISTRICT" Then strQuery = strPolyVariable & " = " & Value Else strQuery = strPolyVariable & " = " & "'" & Value & "'" End If 'Set Polygon Layer field value labelling output table; getting rid of losts of stuff for outputting a valid fieldname every time strFName = Replace(Replace(Replace(Replace(Value, "Weekly Bag Service + ", ""), " ", "_"), ",", "_and"), "/", "_") Dim pFilter As IQueryFilter Set pFilter = New QueryFilter pFilter.WhereClause = strQuery pSelectedPoly.SelectFeatures pFilter, esriSelectionResultNew, False 'select all features in pPointLayer that intersect the selected features in pPolyLayer (selected using pSelectedPoly) Dim pFCur As IFeatureCursor Set pFCur = pPointLayer.FeatureClass.Search(Nothing, False) Dim pFSel2 As IFeatureSelection Set pFSel2 = pPointLayer 'get the selection set for layer 1 and the ids for the selected features Dim pSelectionSet As ISelectionSet Dim pFSel1 As IFeatureSelection Set pFSel1 = pPolyLayer Set pSelectionSet = pFSel1.SelectionSet Dim pEnumIDs As IEnumIDs Set pEnumIDs = pSelectionSet.IDs Dim pGeoCollection As IGeometryCollection Set pGeoCollection = New GeometryBag Dim i As Long For i = 1 To pSelectionSet.Count pGeoCollection.AddGeometry pPolyLayer.FeatureClass.GetFeature(pEnumIDs.Next).Shape Next i Dim pSpatialFilter As ISpatialFilter Set pSpatialFilter = New SpatialFilter With pSpatialFilter Set .Geometry = pGeoCollection .GeometryField = "Shape" .SpatialRel = esriSpatialRelContains End With pFSel2.SelectFeatures pSpatialFilter, esriSelectionResultNew, False Dim pSelectionSet2 As ISelectionSet Dim pFSelect2 As IFeatureSelection Set pFSelect2 = pPointLayer Set pSelectionSet2 = pFSelect2.SelectionSet If pSelectionSet2.Count > 0 Then ExportSelSetFeatureLayertoTable End If End If Value = pEnumVar.Next Loop End Sub Public Sub ExportSelSetFeatureLayertoTable() Dim pDoc As IMxDocument Dim pMap As IMap Set pDoc = ThisDocument Set pMap = pDoc.FocusMap ' Get the selected layer Dim pTable As ITable Dim pFLayer As IFeatureLayer Dim pSelItem As IUnknown Set pSelItem = pDoc.SelectedItem If pSelItem Is Nothing Then MsgBox "Please select a feature feature layer." Exit Sub ElseIf TypeOf pSelItem Is IFeatureLayer Then Set pFLayer = pSelItem Set pTable = pFLayer.FeatureClass Else MsgBox "Please select a feature feature layer." Exit Sub End If 'Confirm layer to be used with user ' Get the dataset name for the input table Dim pDataset As IDataset Dim pDSName As IDatasetName Set pDataset = pTable Set pDSName = pDataset.FullName ' Get the output dataset name ready. In this ' case we are creating a text file in c:\temp Dim pWkSpFactory As IWorkspaceFactory Dim pWkSp As IWorkspace Dim pWkSpDS As IDataset Dim pWkSpName As IWorkspaceName Dim pOutDSName As IDatasetName Dim lblnValidFile As Boolean Dim strFileName As String, strFileLocation As String strFileName = strLName & strFName & ".txt" strFileLocation = "V:\temp\" Set pWkSpFactory = New TextFileWorkspaceFactory Set pWkSp = pWkSpFactory.OpenFromFile(strFileLocation, 0) Set pWkSpDS = pWkSp Set pWkSpName = pWkSpDS.FullName Set pOutDSName = New TableName pOutDSName.Name = strFileName Set pOutDSName.WorkspaceName = pWkSpName Dim pQueryFilter As IQueryFilter Set pQueryFilter = New QueryFilter Dim strField1 As String, strField2 As String, strField3 As String, strField4 As String, strField5 As String, strField6 As String, strField7 As String strField1 = "NAME" strField2 = "PHONE" strField3 = "ADDRESS" strField4 = "CITY" strField5 = "STATE" strField6 = "ZIP" strField7 = "COUNTY" 'Checking table for required fields Dim colTableFields As New Collection colTableFields.Add strField1 colTableFields.Add strField2 colTableFields.Add strField3 colTableFields.Add strField4 colTableFields.Add strField5 colTableFields.Add strField6 colTableFields.Add strField7 Dim strcolTableFields As Variant, chkFieldExists As Long, strProblemMessage As String For Each strcolTableFields In colTableFields chkFieldExists = pTable.FindField(strcolTableFields) If chkFieldExists = -1 Then strProblemMessage = strProblemMessage & "Missing field in " & pDataset.Name & ": " & strcolTableFields & vbCrLf End If Next If strProblemMessage <> "" Then MsgBox "Problem with fields. " & vbCrLf & strProblemMessage 'End ' Stop Exit Sub End If Dim strSubFields As String 'Once residential and commercial is implemented, strField7 should not be exported strSubFields = strField1 & ", " & strField2 & ", " & strField3 & ", " & strField4 & ", " & strField5 & ", " & strField6 & ", " & strField7 pQueryFilter.SubFields = strSubFields Dim pFeatureSel As IFeatureSelection Set pFeatureSel = pFLayer Dim pSelSet As ISelectionSet2 Set pSelSet = pFeatureSel.SelectionSet ' Export selected set of records to text file Dim pExpOp As IExportOperation Set pExpOp = New ExportOperation pExpOp.ExportTable pDSName, pQueryFilter, pSelSet, pOutDSName, Application.hWnd 'Not required can comment out after debugging ' add the table to map Dim pName As IName Dim pNewTable Dim pStTab As IStandaloneTable Dim pStTabColl As IStandaloneTableCollection Set pName = pOutDSName Set pNewTable = pName.Open Set pStTab = New StandaloneTable Set pStTab.Table = pNewTable Set pStTabColl = pMap pStTabColl.AddStandaloneTable pStTab pDoc.UpdateContents End Sub
