Hello,I am trying to create line segments between different cities in the world. I've previously used Spider Tools: http://arcscripts.esri.com/details.asp?dbid=14908 and it worked quite well when I was mapping from one main point to many others. e.g. A -> B, A -> C, A -> D, A -> E....My issue now is that I have connection cities in between, so I need to map A --> BA--> B --> CA --> C --> DA --> B --> E --> F ...Does anybody know of a way I can get these lines to automatically be created? It seems like it would be relatively simple - just connecting the dots based on location, but I can't find anything that would do this for me.Thanks!
I would check out the new "Points to Line" tool that's included at ArcGIS 10.Data Management Tools > Features > Points to Linehttp://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//00170000003s000000.htm
Hi, I'm a beginner in Arcgis and I have a similar problem as dakaye. I need to create segments between points but the problem is that some points are repeated in many segments. That's why I can't use "Points to Line" tool in Arcgis 10. I have data like:segment id, starting point id, end point idIt looks really simple but though I spent a lot of time by searching I still don't know how to figure out. I would appriciate any help. Thanks
could you provide more detail? Maybe a snapshot of your data, or if its ok, post it here?
