Thank you for the quick response Joe. I just wanted to make sure I understand correctly what you are recommending that I could do to address this issue. For the ones which are 100 percent matched, but tied, I could take a sample and verify that they do in fact lie within the same tract. However, I understand that the partial matches may be much more of a problem, if the two candidates are matched at 78 it is more likely that they are in very different locations. Look at two addresses: 1234 S Main ST and 1234 N Main St. Toss out the pre-directions and they are an exact match. That's why partial hits can be problematic. Is it possible then to have Arc count them as matched if there score is 100 but unmatched if it is any less (if I find that I am comfortable with the 100 percent matches)? Absolutely; when you create your locator you can adjust what scores can be a match or a miss. You can also score ties as a miss if you like.Secondly, is there anything known about how Arc chooses 1 of the tied candidates as the match address? Is this process random? Or is it determined by the layout of the line file? It occurred to me if it were random, it is likely to be less of an issue, however if it just chooses the first one it comes across it may be biased in some way. Any insight into this process would be greatly appreciated. I've never really thought about that way; typically I view ties as a problem in the data I'm matching against and go in and fix the problem. If two addresses match against two separate streets, that means the ranges overlap, and I like to fix those.Thanks again for all the help! Cheers. Good luck
