Hi, thereI tried to publish map service with one feature class to ArcGIS online but failed. The error message says "packaging succeeded, but publishing failed." Failed to execute (uploadServiceDefinition). Can someone help me if you have experience on this.Thanks,Amy
Typically, this error is due to tool parameters referencing data that no longer exists. Try the following:�?�In the Results window, right-click the results for which you are creating the service and choose Open. This will open the tool dialog box. If there are any errors (typically, these will be for data that doesn't exist), fix them and rerun the tool. If the tool executes successfully, publish the corresponding result.�?�In the Results window, there will be a result for the execution of the Stage Service tool. Stage Service is executed whenever you publish a service. Expand the Stage Service result, then expand Messages. The messages will give you specifics about why your result could not be published.
Amy,Did you ever find a solution to this? I realize it's an older post, but i'm having the exact same problem right now.Thanks!
Hi Aaastair,Do you see a Service Definition in your My Contents Online?Can you share the Service Definition with me?Can you tell me when you tried to publish, and what your username is?Thanks,Andrew
You can either share the data public and post or message me the Url to it, or if you want to keep it secured you could create a group to share the Service Definition to and invite me to it. (andrewstauffer)It will be best to have the data so we can troubleshoot it internally.Thank you,Andrew
@Kirstin: What version of Desktop are you using?
Most symbol types can be used with a feature service; however, in some cases, the symbols may be downgraded.For line layers, simple line symbols are supported. If other symbols are used, the feature service converts them to a simple line symbol that best represents the original symbol. For example, a cartographic line symbol in the map document may be drawn as a simple solid line in a feature service client. If a line symbol is complex or has multiple layers, the feature service downgrades the line to best represent the original line symbol.For polygon layers, simple fill and picture fill symbols are supported. If other symbols are used, the feature service downgrades them to simple fill symbols. For multilayer fill symbols, the feature service only considers the top layer. Also, a fill symbol's outline symbol has the same level of support as described for line layers above.For point layers, simple marker and picture marker symbols are supported. If other symbols are used, the feature service downgrades them to picture marker symbols. Multilayer marker symbols are also downgraded to picture marker symbols where the layers are merged into a single layer. Mask properties, where a halo can be set for a marker symbol, are not supported.
But I got a way to avoid the error , that is keeping the fiddler running when publishing the service,then the service will be published succeded.
I have a similar issue, when publishing an error appears, the Stage service geoprocess obtains a result , but Upload service geoprocess doesn't. I can't publish feature services from arcmap to ArcGIS Online.
However, I noticed that the 'Status' of the ArcGIS Online Organization is SUSPENDED.
Could you please clarify me if that is reason why I can't publish my services to ArcGIS Online?
Thank you Andrew Stauffer,
Cynthia
Hi Kirstin,
I am too facing the same problem. Did you find a solution to this problem?
