//set a global fixed anchor for the infoWindow when the application loads (initEditing might be a good place) map.infoWindow.setFixedAnchor(esri.dijit.InfoWindow.ANCHOR_UPPERRIGHT); //afterwards wire up the event handling to make sure the map will pan if the entire infoWindow isn't going to fit on the screen dojo.connect(map.infoWindow, "onShow", function() { //Determine the upper right, and center, coordinates of the map var maxPoint = new esri.geometry.Point(map.extent.xmax, map.extent.ymax) var centerPoint = new esri.geometry.Point(map.extent.getCenter()); //Convert these to screen coordinates var maxPointScreen = map.toScreen(maxPoint); var centerPointScreen = map.toScreen(centerPoint); //Subtract the size of the infoWindow, including a buffer. //This will show whether the infoWindow would spill out of the current view. var xDiff = Math.abs(maxPointScreen.x - map.infoWindow.coords.x) - 435; var yDiff = Math.abs(maxPointScreen.y - map.infoWindow.coords.y) - 285; //If required, recalculate a new centerpoint which accounts for the infoWindow if (xDiff < 0) {centerPointScreen.x -= xDiff;} if (yDiff < 0) {centerPointScreen.y += yDiff;} //Pan the map to the new centerpoint (in map coordinates) centerPoint = map.toMap(centerPointScreen); map.centerAt(centerPoint); });
