I'm running into these issues as well. Support tries to help, but they're really not. I followed your steps and saw a huge portion of my map that the status.gdb thinks is successful but has 0 tiles... Is there anything I can do to tell it those tiles are empty? My computer crashed during my initial caching (6 days in) and I have not been able to restart it. I followed support's steps but I've finally given up and deleted it completely. I've just begun re-caching it from the start. This time I'm using exploded instead of compact because I suspect it's compact that's causing my problems.If it succeeds I'll run the processing job to change it to compact. In the meanwhile- does anyone know how to restart failed jobs? All I've witnessed so far is it creating empty bundles for all those that need to be created, then reporting as a success... when it is not.Thanks
I've been attempting to cache a bunch of map services on 10.1 for a few weeks now. Some complete in one shot, others take several attempts and even then, I'm not sure if they are complete or not.
The Caching status dialogue has yet to show results that give any confidence. The "job Status" tab on the Cache Status details dialogue has jobs that are "processing" even though the servers aren't doing anything and I can't seem to cancel them.
I've attempted to run the "manage map server cache status" tool with no success (even though the tool reports "success" after completing). After running that tool, I get "0.0% of the tiles are present" even though I can view the service in the JavaScript viewer and see that there tiles present. I can even open the status.gdb fgdb and get all kinds of info. Is it reliable?
You can run the jobs synchronously (same as "wait for job completion"?) or asynchronously (why not just always async?) report status via map service, or not (I haven't figured that one out yet). Each avenue has different UIs, capabilities, inputs, outputs, etc.
Sometimes within seconds I'll get a result from the Geoproccesing/Results dialog that my cache has been completed, when clearly it hasn't.
I'm running into these issues as well. I followed your steps and saw a huge portion of my map that the status.gdb thinks is successful but has 0 tiles... All I've witnessed so far is it creating empty bundles for all those that need to be created, then reporting as a success... when it is not.
>>Justin, it seems you are running into a bug, can you share your data, server logs & error reports on server with ESRI support, so that we can reproduce & resolve this problem.
I have a ticket open with esri.ca but they've really been unable to help. Unfortunately, they've given me so many suggestions that all that is now gone. My data is still there, but I've re-done my map and the server was wiped out and reinstalled. I began trying this on exploded mode- we'll see how it goes.
Any insight into this caching business would be helpful.
>> It seems that the caching instances are crashing/failing before updating the cache status. Can you check if there are any Error Reports generated on your server by going to �??ArcGIS Server Manager > Logs> Error Reports�?�? if there are some error reports can you share them with us.
