Thank you very much for your quick response Melinda, I have solved it, I downloaded the tool and executed it some time ago. Yesterday I downloaded it again without realizing that I already had it. When executing it in which I had already loaded previously worked Thank you
Hello Patricia. From the error message, it sounds like the tool cannot find the python script it needs in order to run. In Windows Explorer, go to the folder where you saved the Display GTFS in ArcGIS toolbox. There should be a subfolder called "scripts". Inside there, there should be a file called "DisplayGTFSRouteShapes.py". If that file is missing (or if the entire "scripts" folder is missing), then the tool will fail. If that's the case, try downloading a fresh copy of the toolbox.
