try { //code } catch { //empty catch block }
<esri:Map x:Name="BaseWIMS" IsLogoVisible="False" ExtentChanged="BaseWIMS_ExtentChanged" Extent="-98.220507, 36.188768, -96.225105, 34.716448" MouseClick="QueryPoint_MouseClick" > <i:Interaction.Behaviors> <esri:MaintainExtentBehavior /> <esri:ConstrainExtentBehavior ConstrainedExtent="-98.220507, 36.188768, -96.225105, 34.716448" /> </i:Interaction.Behaviors> <esri:ArcGISTiledMapServiceLayer ID="BaseLayer" Url="http://server.arcgisonline.com/ArcGIS/rest/services/ESRI_StreetMap_World_2D/MapServer" /> <esri:ArcGISDynamicMapServiceLayer ID="BoundaryLayer" Url="http://rest.owrb.ok.gov/ArcGIS/rest/services/Special_Studies/Garber_GWQ_Max_Metals_Boundary_WGS84/MapServer" Opacity=".85"/> <esri:ArcGISDynamicMapServiceLayer ID="CountyLayer" Url="http://rest.owrb.ok.gov/ArcGIS/rest/services/Base/SDE_State_County_PLSS_WGS84/MapServer" InitializationFailed="CountyLayer_InitializationFailed" Opacity=".9"/> <esri:ArcGISDynamicMapServiceLayer ID="DynamicLayer" Url="http://rest.owrb.ok.gov/ArcGIS/rest/services/Special_Studies/Garber_GWQ_Max_Metals_WGS84/MapServer" Initialized="ArcGISDynamicMapServiceLayer_Initialized" InitializationFailed="ArcGISDynamicMapServiceLayer_InitializationFailed" /> <esri:GraphicsLayer ID="GraphicsLayer" /> </esri:Map>
private void UserControl_Loaded(object sender, RoutedEventArgs e) { //Show disclaimer at startup, after splash screen. lblDisclaimer_Link(sender, e); BaseWIMS.MinimumResolution = .0001; //Fix for broken ConstrainExtentBehavior in SL4. /*System.Windows.Interactivity.Behavior behavior = new ESRI.ArcGIS.Client.Behaviors.ConstrainExtentBehavior() { ConstrainedExtent = new ESRI.ArcGIS.Client.Geometry.Envelope(-98.220507, 36.188768, -96.225105, 34.716448) }; System.Windows.Interactivity.Interaction.GetBehaviors(BaseWIMS).Add(behavior); */ BaseWIMS.Cursor = Cursors.Hand; }
Would you like me to upload with the reversed YMin and YMax so you can see the effects?
<esri:Map x:Name="BaseWIMS" IsLogoVisible="False" ExtentChanged="BaseWIMS_ExtentChanged" Extent="-98.220507, 34.716448, -96.225105, 36.188768" MouseClick="QueryPoint_MouseClick" > <i:Interaction.Behaviors> <!-- <esri:MaintainExtentBehavior />--> <esri:ConstrainExtentBehavior ConstrainedExtent="-98.220507, 34.716448, -96.225105, 36.188768" /> </i:Interaction.Behaviors> <esri:ArcGISTiledMapServiceLayer ID="BaseLayer" Url="http://server.arcgisonline.com/ArcGIS/rest/services/ESRI_StreetMap_World_2D/MapServer" /> <esri:ArcGISDynamicMapServiceLayer ID="BoundaryLayer" Url="http://rest.owrb.ok.gov/ArcGIS/rest/services/Special_Studies/Garber_GWQ_Max_Metals_Boundary_WGS84/MapServer" Opacity=".85"/> <esri:ArcGISDynamicMapServiceLayer ID="CountyLayer" Url="http://rest.owrb.ok.gov/ArcGIS/rest/services/Base/SDE_State_County_PLSS_WGS84/MapServer" InitializationFailed="CountyLayer_InitializationFailed" Opacity=".9"/> <esri:ArcGISDynamicMapServiceLayer ID="DynamicLayer" Url="http://rest.owrb.ok.gov/ArcGIS/rest/services/Special_Studies/Garber_GWQ_Max_Metals_WGS84/MapServer" Initialized="ArcGISDynamicMapServiceLayer_Initialized" InitializationFailed="ArcGISDynamicMapServiceLayer_InitializationFailed" /> <esri:GraphicsLayer ID="GraphicsLayer" /> </esri:Map>
