When loading drone images into D2M, the mapview does no show the location of the pictures or the path flown by the drone. The images are loaded, and the process runs smooth, output also looks fine.
This could be caused by a known issue with Drone2Map 1.0.1. if that is the version you are using. The only way to get this to work with 1.0.1 is to have your Organization Admin turn off the HTTPS Only option in AGOL.
This has been fixed in Drone2Map 1.1. Sorry for the inconvenience.
