Lucas, You can not retrieve a sublayer from the map using this or any function, only a whole Map Service.
myDynamicLayer.layerDefinitions = [null, "NAME = 'ABC'", null];
My requirement is to define query on featureclass - 1
Set the URL to the ArcGIS Server REST resource that represents a single layer or table, e.g. http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer/5. Note the number "5" at the end of the URL which indicates which specific layer you want to query when querying a map service or a feature service. For an image server, the map service itself is the 'single' layer, so the URL would end with "/MapServer" (without a number).
<esri:ArcGISDynamicMapServiceLayer id="Parcels" url="http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/BloomfieldHillsMichigan/Parcels/MapServer"/> var arc:ArcGISDynamicMapServiceLayer = map.getLayer("Parcels") as ArcGISDynamicMapServiceLayer();
