Great. Thanks for the quick reply. Any idea where I would find this information?
No, can you give me some examples.
server = smtplib.SMTP('333.333.333.3')
server = smtplib.SMTP('my.email.server', 22)
error: [Errno 10061] No connection could be made because the target machine actively refused it
Any one have this error?[Errno 10061] No connection could be made because the target machine actively refused it
# import smtplib module import smtplib # This is the body of the email file = open('c:/temp/log.txt').read() # Create a connection to our email server via the IP address server = smtplib.SMTP('333.333.333.3') # The key here is the word "Subject:" It's a keyword to put the text that follows on the subject line. subj = "Subject: Python Email" # Send out the email (must separate subj+"\n"+file or all will go into subject line) # 3 ARGS only: fromEmail, toEmail, subject and body server.sendmail('rdh@xyz.com','rdh@xyz.xyz.com', subj+"\n"+file) # Terminate the connection to server and quit server.quit()
Anyone written python email code that sends an email if the python script fails?
import arcgisscripting, smtplib, os, sys, traceback from email.MIMEMultipart import MIMEMultipart from email.MIMEBase import MIMEBase from email.MIMEText import MIMEText from email.Utils import COMMASPACE, formatdate from email import Encoders gp = arcgisscripting.create(9.3) #********************************************************************** # Description: # Emails a file. File is assumed to be a zip file. Routine either attaches # the zip file to the email or sends the URL to the zip file. # # Parameters: # 1 - File to send. # 2 - Email address to send file. # 3 - Name of outgoing email server. # 4 - Output boolean success flag. #********************************************************************** def send_mail(send_from, send_to, subject, text, f, server, smtpUser="", smtpPwd=""): try: msg = MIMEMultipart() msg['From'] = send_from msg['To'] = COMMASPACE.join(send_to) msg['Date'] = formatdate(localtime=True) msg['Subject'] = subject msg.attach( MIMEText(text) ) part = MIMEBase('application', "zip") # Change if different file type sent. part.set_payload( open(f,"rb").read() ) Encoders.encode_base64(part) part.add_header('Content-Disposition', 'attachment; filename="%s"' % os.path.basename(f)) msg.attach(part) smtp = smtplib.SMTP(server) # If your server requires user/password if smtpUser != "" and smtpPwd != "": smtp.login(smtpUser, smtpPwd) smtp.sendmail(send_from, send_to, msg.as_string()) smtp.close() except: tb = sys.exc_info()[2] tbinfo = traceback.format_tb(tb)[0] pymsg = "PYTHON ERRORS:\nTraceback Info:\n" + tbinfo + "\nError Info:\n " + \ str(sys.exc_type)+ ": " + str(sys.exc_value) + "\n" raise Exception("SendEmailError:" + pymsg) if __name__ == '__main__': sendto = gp.GetParameterAsText(0).split(";") fromaddr = gp.GetParameterAsText(1) subject = gp.GetParameterAsText(2) text = gp.GetParameterAsText(3) zipfile = gp.GetParameterAsText(4).replace("\\",os.sep) maxsize = int(gp.GetParameterAsText(5)) * 1000000 smtpMailServer = gp.GetParameterAsText(6) smtpUser = gp.GetParameterAsText(7) smtpPwd = gp.GetParameterAsText(8) try: zipsize = os.path.getsize(zipfile) #Message"Zip file size = " gp.AddMessage(gp.GetIDMessage(86156) + str(zipsize)) if zipsize <= maxsize: send_mail(fromaddr, sendto, subject, text, zipfile, smtpMailServer, smtpUser, smtpPwd) #Message "Sent zipfile to %s from %s" gp.AddIDMessage("INFORMATIVE", 86154, sendto, fromaddr) gp.SetParameterAsText(9, "True") else: #Message "The resulting zip file is too large (%sMB). Must be less than %MB. Please # digitize a smaller Area of Interest." gp.AddIDMessage("ERROR", 86155, str(round(zipsize / 1000000.0, 2)), str(round(maxsize / 1000000.0, 2))) gp.SetParameterAsText(9, "False") raise Exception except: # Return any python specific errors as well as any errors from the geoprocessor tb = sys.exc_info()[2] tbinfo = traceback.format_tb(tb)[0] pymsg = "PYTHON ERRORS:\nTraceback Info:\n" + tbinfo + "\nError Info:\n " + \ str(sys.exc_type)+ ": " + str(sys.exc_value) + "\n" gp.AddError(pymsg) #Message "Unable to send email" #gp.AddIDMessage("ERROR", 86157) gp.AddError("ERROR, Unable to send email")
