Justin, the archive "hosts" have just one line:::1 arcgis localhostwhere "arcgis" is name of machine.Other Idea?thanks
I installed the ArcGIS Server 10.1 in Linux Fedora 6 x64 (Path: /home/arcgis/server), but when I try to create a new site in Manager ArcGIS Server, this error occurs:Failed to create the site. Failed to create the service 'System/CachingTools.GPServer'.The Link http://support.esri.com/en/knowledgebase/techarticles/detail/40398 of support not working, because my path is /home/arcgis/server.What's happen?thanks.
This issue is commonly caused by incorrect settings in your etc/hosts file. Clear everything out of your etc/hosts file except an entry that reads something like: 127.0.0.1 localhost.localdomain localhostIf you do not want to delete anything, then please simply comment any other items out with an '#'. Let me know if that works. Thanks-Justin
Thank you for the update. Please make it say this exactly: 127.0.0.1 localhost.localdomain localhostJust copy and paste it. Comment out the line you have in there currently. That most likely is the cause of the issue. Thanks-
