I'm trying out ArcGIS online and after my learning, I'm able to create a map and a dashboard.
I would like to create a layer for the map that comes from our public REST server.
I first created a 2 line Excel file that I saved to CSV format. I chose upload from My Computer and the file created a dot on my map at the coords that I gave it from the csv file. Perfect.
I changed the file on my disk, and updated the file manually, works too.
Next I took that same file and set it up on my server. I can connect to it fine from Chrome and download it.
When I try and get the file from ArcGIS Online it as a csv url, it came back with an error:
"The CSV, http://myserverurl.com/api/testfile, is not accessible and cannot be added to the map."
This tells me noting...
I checked the url headers, but I don't really know what the map expects. This is a simple Excel file saved to my server with 1 record: name, latitude,longitude, and a second line with 3 values.
Can you please point me in the right direction for what I'd like to do?
The data needs to update every day automatically, so I thought a web rest service would be best.
I can also send it as a json if necessary.
What's the correct way to for ArcGIS Online to consume a layer that the data updates every day, without any manual intervention.
Thank you
