I know, VBA is history, but some of use are still using it on 9.2.My question is: how do you load an SDE annotation layer using VBA code? We're now using SDE 9 and the way SDE stores annotation appears to be different than when we were using older version of SDE. My old code, that worked prior to going to SDE 9n was as follows: Set pFeatureClass = pFeatureWorkspace.OpenFeatureClass("CALGIS.CNTST_LANDUSE_1P2007_LL") Set pFeatureLayer = New CoverageAnnotationLayer pFeatureLayer.Name = "Landuse Annotation Leadlines - 1P2007" 'set Layername pFeatureLayer.MinimumScale = 4000 pFeatureLayer.ShowTips = True pMap.AddLayer pFeatureLayer 'Add Layer to Map pMxDoc.ActiveView.ContentsChangedI get and error message indicating that an "Object Variable or With Block not set", how would I change the code to work with the new SDE annotation? What ArcObject should I now be using?
pFeatureLayer.DataSourceType = "SDE Feature Class"
