Weet iemand hoe je een polygon op breedte kunt queryen? Ik werk eraan om percelen te vinden met een minimale perceelbreedte van 50 voet en meer. <\/P><\/BODY><\/HTML>
You need the Minimum Area Bounding Rectangle... also called Rectangle_by_Area
http://pro.arcgis.com/en/pro-app/tool-reference/data-management/minimum-bounding-geometry.htm
I think ArcMap has it to and everything except the circle doesn't require and advanced license.
If you have shapefiles and a basic license level, then you can use
https://www.arcgis.com/sharing/tools/bridge?url=https%3A%2F%2FCarleton-U.maps.arcgis.com%2Fhome%2Fitem.html%3Fid%3D564e2949763943e3b9fb4240bab0ca2f&exp=858845
