Hello, I upgraded from 6.02 to 6.1.
I can do everything except having ESRI Map Designer in Cognos "Launch".
What can be the problem?
Has this issue been resolved? If not, please check the web server configuration again.
Configure Microsoft Internet Information Services 7.x or 8.x—Esri Maps for IBM Cognos | ArcGIS
Thanks.
The absence of the Esri Maps designer indicates one of the following:
If both of these were done, I recommend that you do the following
Also the Esri Maps Designer will not launch if you are in Compatibility Mode
Thanks Thomas, your recommendation worked. After reinstalling EM4C the Designer had appeared and I was able to make/edit map enabled reports.
Excellent!
