Have a shared key field between point and line feature, could also calculate start/stop x and y. Is it possible to batch move my lines?
Brita, since you have points and polylines. you could use the points as reference points for...
About spatial adjustment—Help | ArcGIS Desktop
If everything was offset by an equal amount, I suspect that something wasn't defined properly about the coordinate system. If the offsets are irregular, then spatial adjustment does the vector equivalent to "warping" or "georeferencing" an image in raster world.
Sorry that might help! Have the latest version of ArcGIS Pro & Desktop, advanced + all extensions on Desktop only. Thank you so much for any help you can offer! Dan Patterson
It is possible to do both... but what software are you using?
