private Map _currentmap; public CoordinateTool(Map currentmap) { // TODO: Complete member initialization this._currentmap = currentmap ?? MapApplication.Current.Map; if(_currentmap != null) { _currentmap.MouseClick += CurrentmapOnMouseClick; } CurrentCoordinates = new CurrentProjectionCoordinates() {X = "0", Y = "0"}; DdCoordinates = new DDCoordinates() {X_DD = "0", Y_DD = "0"}; DmsCoordinates = new DMSCoordinates() {X_DMS = "0", Y_DMS = "0"}; //initialise service endpoints _geometryservice = new GeometryService(MapApplication.Current.Urls.GeometryServiceUrl); _geometryservice.ProjectCompleted += GeometryserviceOnProjectCompleted; _geometryservice.Failed += GeometryserviceOnFailed; } private void CurrentmapOnMouseClick(object sender, Map.MouseEventArgs mouseEventArgs) { MapPoint point = mouseEventArgs.MapPoint; if (point != null) { CurrentCoordinates.X = string.Format("{0:N4}", point.X); CurrentCoordinates.Y = string.Format("{0:N4}", point.Y); // Coordinates in WGS84 format Graphic pointgraphic = new Graphic() {Geometry = point}; if (_geometryservice != null && _currentmap != null) { IsReprojection = false; if (!_geometryservice.IsBusy) { _geometryservice.ProjectAsync(new List<Graphic>() { pointgraphic }, new SpatialReference(WKID_WGS84)); } } } } private void GeometryserviceOnFailed(object sender, TaskFailedEventArgs taskFailedEventArgs) { MainApplication.Handle("Error", taskFailedEventArgs.Error); } private void GeometryserviceOnProjectCompleted(object sender, GraphicsEventArgs graphicsEventArgs) { Graphic resultgraphic = graphicsEventArgs.Results.FirstOrDefault(); if (resultgraphic != null) { if (!IsReprojection) { IsReprojection = false; MapPoint point = resultgraphic.Geometry as MapPoint; if (point != null) { DdCoordinates.X_DD = string.Format("{0:N4}", point.X); DdCoordinates.Y_DD = string.Format("{0:N4}", point.Y); DmsCoordinates.X_DMS = string.Format("{0:N4}", DMSCoordinates.FromDecimalDegrees(point.X)); DmsCoordinates.Y_DMS = string.Format("{0:N4}", DMSCoordinates.FromDecimalDegrees(point.Y)); } } else { //.......................... } } }
public class CurrentProjectionCoordinates : NotificationBase { protected string x; protected string y; private double surrogate = 0; public string X { get { return (x); } set { x = value; OnNotifyPropertyChanged("X"); } } public string Y { get { return (y); } set { y = value; OnNotifyPropertyChanged("Y"); } } } public class DDCoordinates : NotificationBase { private string x; private string y; public string X_DD { get { return (x); } set { x = value; OnNotifyPropertyChanged("X_DD"); } } public string Y_DD { get { return (y); } set { y = value; OnNotifyPropertyChanged("Y_DD"); } } } ........
