function createMap(webmapitem) { var mapDeferred = esri.arcgis.utils.createMap(webmapitem, "map", { mapOptions: { slider: configOptions.displaySlider, sliderStyle: 'small', wrapAround180: !configOptions.constrainmapextent, showAttribution: true, //set wraparound to false if the extent is limited. logo: !configOptions.customlogo.image //hide esri logo if custom logo is provided }, ignorePopups: false, bingMapsKey: configOptions.bingmapskey }); mapDeferred.addCallback(function (response) { //add webmap's description to details panel if (configOptions.description === "") { if (response.itemInfo.item.description !== null) { configOptions.description = response.itemInfo.item.description; } } //initialExtent = response.map.extent; initialExtent = new esri.geometry.Extent({"xmin":-12345,"ymin":12345,"xmax":-12345,"ymax":12345,"spatialReference":{"wkid":102100}}); if (configOptions.extent) { var extent = new esri.geometry.Extent(dojo.fromJson(configOptions.extent)); initialExtent = extent; } configOptions.owner = response.itemInfo.item.owner; document.title = configOptions.title || response.itemInfo.item.title; //add a title if (configOptions.displaytitle === "true" || configOptions.displaytitle === true) { configOptions.title = configOptions.title || response.itemInfo.item.title; dojo.create("p", { id: 'webmapTitle', innerHTML: configOptions.title }, "header"); dojo.style(dojo.byId("header"), "height", "38px"); } else if (!configOptions.link1.url && !configOptions.link2.url) { //no title or links - hide header esri.hide(dojo.byId('header')); dojo.addClass(dojo.body(), 'embed'); dojo.query("html").addClass("embed"); } //get the popup click handler so we can disable it when measure tool is active clickHandler = response.clickEventHandle; clickListener = response.clickEventListener; map = response.map; //Constrain the extent of the map to the webmap's initial extent if (configOptions.constrainmapextent) { webmapExtent = response.map.extent.expand(1.5); } if (map.loaded) { initUI(response); } else { dojo.connect(map, "onLoad", function () { initUI(response); }); } map.setExtent(initialExtent); var MapServiceLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://mywebsite.com/arcgis/rest/services/Blah/MapServer"); map.addLayer(MapServiceLayer); }); mapDeferred.addErrback(function (error) { alert(i18n.viewer.errors.createMap + " : " + dojo.toJson(error.message)); }); }
