I need to use two maps for most of my slider maps, Simply removing one layer will not suffice.
Can we get this functionality added in Web App Builder?
well I have firestations with their 1.5 mile response areas currently with 26. we are looking at moving some stations and adding some so the firestation layer and response area layers are all different and when you just swipe one away it does not work I need to be able to swipe the two different maps of those two in order to show the change.
Hi Kenneth
what would be the business case to require a swipe of two maps? If the swipe tool is able to swipe layers?
Kenneth,
Nothing like that exists then. And as a developer I can not see the dev team adding something like this just because of the amount of re-coding of the whole app structure that would have to happen for this.
Yes but it doesnt have the swipe map for two maps. it has to be one map that you slide the layer. I am looking for the two maps so you slide the entire map back and forth between two maps.
WAB has a swipe widget. http://gislap183:3344/webappbuilder/help/index.html#//03w30000005z000000
There is also the custom widgets enhanced basemap gallery widget:
Enhanced Basemap Gallery Widget 1.3 - 12/14/2015
