Running script Landscape_Fragmentation_Tool...OUTPUT DATASET NAME IS: C:\Users\Beth\Documents\ArcGIS\lftmod\landfragmod.gdb\C:\Users\Beth\Documents\ArcGIS\lftmod\landfragmod.gdb\lfttestsat
try: # enable the overwrite option... arcpy.env.overwriteOutput = 1 # check out spatial analyst license... arcpy.CheckOutExtension("spatial") # script parameters... landcover = sys.argv[1] # input raster dataset edgeWidth = float(sys.argv[2]) # number wksp = sys.argv[3] # output raster location FragMap_lyr = sys.argv[4] # display layer ## landcover = r"C:\Projects\ForestFragModel\test_landcover\lc_forest_nonforest.img" ## edgeWidth = 305 # string ## wksp = r"C:\Temp" # output raster location ## FragMap_lyr = "ff_test" s = time.clock() #----------------------------------------------------------- # CREATE OUTPUT RASTER NAME FROM WORKSPACE AND LAYER NAME... # if workspace is a geodatabase, no extension needed... if ".gdb" in wksp or ".mdb" in wksp: FragMap = "%s\\%s" % (wksp,FragMap_lyr) # otherwise use ".img" extension (no length / character restrictions)... else: FragMap = "%s\\%s.img" % (wksp,FragMap_lyr) # provide user feedback... arcpy.AddMessage("\nOUTPUT DATASET NAME IS:") print "\nOUTPUT DATASET NAME IS:" arcpy.AddMessage("\n\t%s\n" % FragMap) print "\n\t%s\n" % FragMap
