Hi
I am running in to an issue in Portal 10.7 when I try to create a view layer from a hosted feature layer, it seems to run through ok and creates the layer in the Contents but then this error appears, and I am unable to use the View in any webmap etc without the same error coming up
The Server manager shows this error:
Error executing tool. Export Web Map Task : Failed to create layer from service at https://xyz/server/rest/services/Hosted/Soil_Collection_Points_map1/FeatureServer/0. Failed to execute (Export Web Map). Failed to execute (Export Web Map Task).
I have been able to create views from some hosted features layers that were newly created from Survey123 Connect for example.
Any thoughts on whats happening here?
Chris
