I'm following this steps to sync a database, Sync offline edits—ArcGIS Runtime SDK for Android | ArcGIS for Developers .
But I can't realize where I need to put the parameters [1] on android code [2]. And I think that I'm getting error on ArcGIS log because I'm not using this parameters right [3].
How can I fix this?
See prints in attachment, please.
My error happens inside:
if (geodatabaseSyncTask.getLoadStatus() == LoadStatus.FAILED_TO_LOAD) { dealWithException(geodatabaseSyncTask.getLoadError());
from Sync offline edits—ArcGIS Runtime SDK for Android | ArcGIS for Developers (method createGeodatabaseSyncTask())
So, I've tried to execute the method generateGeodatabaseParameters() before createGeodatabaseSyncTask() but I've got a excpetion with:
Cause: Feature service is not loaded, it needs to be loaded before passed into the sync task.Message: Invalid access range
How can I proceed?
Placing that info in the headers of the request configuration will not get you the output you seek as this would modify every header that you send to ArcGIS Online. Instead, I encourage you to look at the GenerateGeodatabaseParameters since this will allow you to modify the arguments through class methods:
GenerateGeodatabaseParameters| arcgis-android
