Hi Mary,
I am facing the same problem in AG Portal. My geocoder works fine when I use it in the Geocoder Widget in Web App Builder but gives the same warning when I try to use it in Utility Services of May Portal. So I can not make use of it in the Web Maps.
Have you been able to solve it?
Hi. For us it turned out to be a problem with the SSL certificate on our server. Since we were going through ArcGIS Online, they required an intermediate certificate, I don't know if that applies to a Portal installation and configuration.
Sorry I couldn't be more helpful.
Hi Tuna,
Is SSL enabled on your geocoding service? If so, use this link to check if there are any issues with the certificate installation: SSL Checker
If no issues come up with the certificate, then I would suggest contacting technical support to look into this issue.
-Kelly
Thank you for your valuable answers. I will have SSL issue checked by IT Dept. and share the result.
