I've been trying to run the "Mosaic to New Raster" tool on georeferenced images but it is failing after several hours with an unexpected error. Each time it fails on different images. It has not been consistent. Does anyone know what the problem is and how I can work through it? I'm using 9.3.1 sp2
I'm having similar issues with ArcGIS Pro. It seems to work the first time, any attempts after that instantly fail. It is almost like I've used up the memory to re-run the tool. I've tried closing the tool, but have had no luck. Any folks from @esri have a solution?
It also seems to work if I completely close the project and re-open it, then re-run the tool.
