Erik,The overviews at the mosaic dataset level are different to the overviews (pyramids) at the dataset level. The pyramid (.ovr) files build by FWTools should still be used by the system. If you try to rebuild pyramids then these files should be replaced by files created by ArcGIS.The overviews built by the mosaic datasets can encompass multiple source datasets, while the pyramids on the source can only exist one per each source dataset. I hope this helps.Robert
