Error: Propriété inconnue : dispatchResetEvent. at mx.collections::ListCollectionView/http://www.adobe.com/2006/actionscript/flash/proxy::getProperty()[/Users/justinmclean/Documents/ApacheFlex4.11.0/frameworks/projects/framework/src/mx/collections/ListCollectionView.as:940] at JSON$/stringifySpecializedToString() at JSON$/stringify() at com.esri.ags.utils::JSONUtil$/encode() at com.esri.ags.tasks::Geoprocessor/toURLVariables() at com.esri.ags.tasks::Geoprocessor/submitJob() at com.esri.ags.tasks::PrintTask/submitJob()
Anthony, If you look at the system requirements page you will see that the minimum SDK is 4.6https://developers.arcgis.com/en/flex/system-reqs.html
Hi,I was updating the Flex SDK to 4.11 version for my project, but when I use a Task (for example PrintTask), there is an error with the JSON utilities include in the Flex Arcgis API.This is the stack trace when I launch task.Error: Propriété inconnue : dispatchResetEvent. at mx.collections::ListCollectionView/http://www.adobe.com/2006/actionscript/flash/proxy::getProperty()[/Users/justinmclean/Documents/ApacheFlex4.11.0/frameworks/projects/framework/src/mx/collections/ListCollectionView.as:940] at JSON$/stringifySpecializedToString() at JSON$/stringify() at com.esri.ags.utils::JSONUtil$/encode() at com.esri.ags.tasks::Geoprocessor/toURLVariables() at com.esri.ags.tasks::Geoprocessor/submitJob() at com.esri.ags.tasks::PrintTask/submitJob()I don't know if the problem come from Flex SDK or JSONUtil, but if I use the Flex SDK 4.9.1, it works.Could you give me your feed back if I you resolve this problem for the next release of Flex Arcgis library.Best regards.
