Hello: I have a point dataset which has 20+ fields indicating different storm surge elevations. For instance, one field indicates storm 1, and contains 200 water surface elevation records. The second field indicates storm 2, with also 200 water surface records, and so on. The returns for each storm are present on the same record/point, just different values. I want to generate 20+ point feature classes, one for each storm by extracting each field into its own dataset. Following this process, I'd like to run a batch process for each storm point file that generates a raster for each storm scenario. I know how to do this manually, but it would take a lot of time considering the number of steps involved. Any help would be greatly appreciated.
Thank you!
-Mark
