//find results return an array of findResult. map.graphics.clear(); var dataForGrid = []; //Build an array of attribute information and add each found graphic to the map dojo.forEach(results, function(result) { var graphic = result.feature; dataForGrid.push([result.layerName, result.foundFieldName, result.value]); switch (graphic.geometry.type) { case "point": graphic.setSymbol(markerSymbol); break; case "polyline": graphic.setSymbol(lineSymbol); break; case "polygon": graphic.setSymbol(polygonSymbol); break; } // Get the geometry var pt = graphic.geometry; // Center the map at the point and zoom to scale level 12 map.centerAndZoom(pt,12); map.graphics.add(graphic);
You will probably have to string a couple of functions together, which isn't too hard to do once you know what you are doing.e.g. This example here - http://developers.arcgis.com/en/javascript/samples/find_map/So that's finding a feature and returning the geometry, after that you just need to get that geometry and zoom to it.So in the code, note the bits I've added in //find results return an array of findResult. map.graphics.clear(); var dataForGrid = []; //Build an array of attribute information and add each found graphic to the map dojo.forEach(results, function(result) { var graphic = result.feature; dataForGrid.push([result.layerName, result.foundFieldName, result.value]); switch (graphic.geometry.type) { case "point": graphic.setSymbol(markerSymbol); break; case "polyline": graphic.setSymbol(lineSymbol); break; case "polygon": graphic.setSymbol(polygonSymbol); break; } // Get the geometry var pt = graphic.geometry; // Center the map at the point and zoom to scale level 12 map.centerAndZoom(pt,12); map.graphics.add(graphic);
