If this is not the right venue to ask, who can I request that from? Thanks!
The workaround my coworker Jon Fisher helped me figure out was to publish my own custom empty basemap in ArcGIS Server with 1:100, 1:250, and 1:500 zoom levels in addition to all the other standard arcgis zoom levels. Then I pointed my arcgis.com map to that basemap. Hope this helps you!aloha,Steph
I have been looking at troubleshooting this same topic. I have tried services published using ArcGIS for Server as well as services published directly to AGOL. I have switched basemaps, and even set my own data as basemaps, but no matter how I mix it up I cannot zoom in beyond 1:1,128 within AGOL. Any suggestions? (I've seen a couple of similar topics but this seems to be the best fit that I've found)ThanksPaul
One question for you, however. Why are you trying to publish a basemap that is empty? What exactly are you trying to achieve? You can make any layer from ArcGIS Server "the basemap" when you add it to a web map. If that layer happens to be dynamic, the map will zoom dynamically, not from tiles. Depending on the extent of your area of interest, generating empty tiles for larger scales could yield a lot of tiles.Thanks,Mike
