I've now solved this issue and it turns out it was very simple!All the ESRI documentation that I've read tells you to apply the claro class to the body tag, but actually, I only need to apply it to the map div.It's one of those things that is so simple, you over look it.
thanks for your reply. I've attached a screenshot of the issue I have - because I haven't included claro.css in my page (to avoid getting all the unwanted reset styles), the attached image shows what my zoom slider looks like at the moment!Not very attractive!Your reply seemed to indicate the practical option available to me is to refined the classes used to style this slider, but is there any way to find out a complete list? Maybe there is and that's a silly question but I don't know! If I open claro.css, it's a compressed css file, so hard to easily get the info out of there (again, unless I'm missing something!).The same thing happens with my popups, so these would need to be styled too.Thanks.
I think I have misunderstood your original suggestion, but I would be grateful if you could expand further.claro.css contains reset css for default fonts, sizes, margins etc to be used. And then it does contain - like you say - the styling for the zoom slider and popups.But short of redefining everything, I'm not sure I follow your suggestion!If I don't want all the body.claro to be defined, but I do want classes like.dijitSliderButtonInner which are part of the slider.There's a good chance I'm missing something obvious here, but grateful if you could explain further!
Thanks for the reply.Unfortunately that suggestion you have made is not practical. It's not feasible to redefine everything that claro.css defines, as that will mean a lot of unnecessary time being spent and extra code being generated.I don't really want to use claro.css anyway. I have a customer's template and branding guidelines which do the job - all I want to do is be able to style the zoom slider somehow. But unfortunately the styles seem to be locked away and I need to find a way of accessing them.Can anyone suggest a way to style the zoom slider?
HiI am trying to integrate a map into a customer template, using their stylesheets etc, with the Javascript API.I notice that if I include claro.css into my file, it styles everything on the page. It contains default styling which I simply don't want or need. What I really want is to have the zoom slider styled properly, but I don't see how I can achieve this without all the other CSS that I don't need.I'm new to ArcGIS Server and the JS API so would be grateful if someone can advise how I can access styling on the zoom slider without other styles I don't need.Thanks.
