Do not forget that you will most likely have to generate statistics to change it from a 'black box' to looking like data is there. The reason for this is that usually ascii files come in with the entire range of possible values. When you apply the standard deviation stretch then the raster will display as expected. Also don't forget the Ascii to Raster tool.
I have a problem When I´m trying to open ascii grid file. When I´m trying to open file, I create pyramids, as Arcmap asks. Then, when it shows as a black box, i use "conversion tools ->ASCII to raster". Then i can get something out. My problem is, how can I set right coordinates in this map? I´m trying to make a visibilityanalysis from viewshed in arcmap. So i need this ascii grid -file, because it contains hightmodels that I need. So I need to add in this file few shapefiles, but all i get is that this new map doesn´t show in same area as other shapefiles. I can see it only if I press "zoom to layer".
